TwinTurbo.NET: Nissan 300ZX forum - Fuel lines are straight. The plugs are soaked...
Andrewhuffman
on December 17, 2009 at 10:15 AM
New motor wont start.
posted by Andrewhuffman
on December 17, 2009 at 09:15 AM
I turned the motor over with no plugs in, and put new plugs in, unplugged the Fuel pump... no dice. It was close... One of my first attempts was to spray starter fluid into the mani, so that still pooled in there.
Andrewhuffman
09:15:09 12/17/09
Are the plugs soaked from gas? (n/m)
Josher
09:22:25 12/17/09
Sounds like your plugs are fouled, also check if your maf
Ice95z
09:42:23 12/17/09
check to see if you reversed the fuel line by accident
NobleZ
09:49:55 12/17/09
Fuel lines are straight. The plugs are soaked... -
Andrewhuffman
10:15:28 12/17/09
Are all six are soaked?
CaliguyPurdue (Selin Design)
11:20:12 12/17/09
changed the MAF, changed PTU.
Andrewhuffman
10:31:36 12/17/09
did you check the CAS? also, did you change the fuel filter?
NobleZ
10:52:26 12/17/09
Try posting in the technical forum. Its why its there. (n/m)
z32z
11:42:24 12/17/09
This is the technical forum . Technically speaking ! (n/m)
xteam300tt
13:32:22 12/17/09
This post was in the General forum before it was moved here. (n/m)
NytWolf
17:25:52 12/17/09
Recheck your timing belt
NytWolf
11:43:41 12/17/09
all 6 were soaked. new fuel filter. checked CAS.
Andrewhuffman
15:33:17 12/17/09
You're not listening nor do you comprehend a 4-stroke motor (n/m)
NytWolf
16:54:26 12/17/09
The timing belt is not wrong!
Andrewhuffman
17:11:02 12/17/09
LOL -- How do you know it's not wrong?
NytWolf
17:21:29 12/17/09
Re: LOL -- How do you know it's not wrong?
canyoncarver
22:13:46 12/18/09
It Lives!~!!!
Andrewhuffman
18:16:20 12/17/09
Re: It Lives!~!!!
Andrewhuffman
19:11:32 12/17/09
vid
Andrewhuffman
18:32:06 12/17/09
Re: vid
ZTurboFan
18:41:12 12/17/09
vid
Andrewhuffman
18:54:48 12/17/09
Re: vid
ZTurboFan
19:01:49 12/17/09
Re: Re: vid
Andrewhuffman
19:12:21 12/17/09
No exhaust...
ZTurboFan
19:40:43 12/17/09
Re: No exhaust...
Andrewhuffman
20:04:11 12/17/09
Re: Re: No exhaust...
ZTurboFan
20:20:30 12/17/09
Re: Re: Re: No exhaust...
Andrewhuffman
23:29:29 12/17/09
Well...
ZTurboFan
00:39:36 12/18/09
Re: Well...
Andrewhuffman
11:12:20 12/18/09
Update
Andrewhuffman
14:31:23 12/18/09
Like I said, timing issue
canyoncarver
17:10:04 12/18/09
Timing
ZTurboFan
19:48:11 12/18/09
Re: Timing
Andrewhuffman
01:27:33 12/19/09
Re: Re: Timing
Andrewhuffman
01:28:47 12/19/09
Assumptions...are...BAD
ZTurboFan
10:55:21 12/19/09
Re: Assumptions...are...BAD
Andrewhuffman
14:09:29 12/19/09
Next Steps
ZTurboFan
16:06:12 12/19/09
Re: Next Steps
Andrewhuffman
20:37:50 12/19/09
1 Year+
ZTurboFan
21:40:21 12/19/09
Timing
Andrewhuffman
11:18:05 12/20/09
Ok. Good.
ZTurboFan
11:49:58 12/20/09
Update
Andrewhuffman
13:51:01 12/20/09
Imprint, not inpring.
Andrewhuffman
13:56:11 12/20/09
#1-90, #3-60, #5-90
Andrewhuffman
14:02:07 12/20/09
Re: #1-90, #3-60, #5-90
ZTurboFan
14:29:26 12/20/09
Re: Re: #1-90, #3-60, #5-90
Andrewhuffman
14:39:43 12/20/09
That's a bummer...
ZTurboFan
16:41:00 12/20/09
Re: That's a bummer...
Andrewhuffman
20:45:24 12/20/09
Well...one more...
ZTurboFan
09:36:27 12/21/09
Update
Andrewhuffman
14:18:06 12/21/09
Re: Update
Andrewhuffman
14:33:22 12/21/09
My Thoughts...
ZTurboFan
15:27:14 12/21/09
Re: My Thoughts...
Andrewhuffman
15:53:29 12/21/09
Lifter Rebuild
ZTurboFan
22:13:39 12/21/09
Oh, and good on the cams
ZTurboFan
22:15:40 12/21/09
It Lives!~!!!... again
Andrewhuffman
19:57:11 01/01/10
WTF you are an idiot. This assuming
dream Z (MD)
02:37:57 01/02/10
Re: WTF you are an idiot. This assuming
Andrewhuffman
06:03:19 01/02/10
Get a bigger computer screen.
dream Z (MD)
11:41:00 01/02/10
